ACAD 11 Organizer
I cannot get the organizer palette to appear in ArchiCAD 12 on a Mac running 10.5.8. It does not appear when chosen from the Palette menu or from the Navigator. I am finishing a project and need to create a consolidated set of sheets, is there any way to do that other than through the Organizer? I am running in educational mode since I started this project years ago when in college.
2 Replies 2
Hi Bill,
Check in the 'Window' menu under 'Palettes' to see whether the organizer palette is actually open. If the button is highlighted but it's still not visible, it may be off the screen. Reset your palette scheme in the work environment and it should go back to its default position.
Hope that helps.
Peter,
Thanks for the cure, selecting the default palette scheme did the job.
Bill
