ADDING A SINK TO COUNTER
HEY EVERYONE.. I NEED SOME HELP. I WANT TO USE THE KITCHEN COUNTER DRAWER 11 AND ADD A MULTI STYLE SINK 11 TO IT. HOW DO I CUT A HOLD IN THE COUNTER FOR THE SINK. I HAVE TRIED SOLID ELEMENT OPERATIONS BUT IT DOESNT WORK. AM I DOING SOMETHING THAT CANT BE DONE OR AM I DOING SOMETHING WRONG. THANKS...
ARCHICAD 11, WINDOWS XP PRO.
Use a slab, that is a bit smaller than the sink, as the operator to SEO out the worktop.
Then put the slab on a hidden layer so it isn't displayed.
(Out of curiosity, how does the draw open if you have a sink going thru it? I presume its just a dummy panel!)
THANK YOU I WILL TRY THAT. AND YES I WANT TO CREATE AN ADA COMPLIANT ROLLUNDER KITCHEN SINK AND I AM USING THIS OBJECT FOR THE LOOK ONLY. THE DRAWER WILL BE USELESS.
Ahh, a rollunder sink for disabled access. I didn't think of that!
