2022-08-11 02:35 PM - edited 2022-08-11 02:46 PM
How do I add 3x areas and create a new row in a table, while not adding the total area?
Please see attached
(note: total area - Site Area 687.04)
Solved! Go to Solution.
2022-08-11 05:12 PM
The easiest way is to give the same name to 3 zones and select "merge items" in the upper left corner.
If you need different names for these zones, as an option, separate these zones into 2 different categories with the name you need (Site Area and Site Coverage), display these fields (Zone Category) in schedule and select "marge items".
2022-08-11 03:40 PM
Add another field so you can flag that for subtotals. You would have to pick a field where you can set something to differentiate your zones.
2022-08-11 05:12 PM
2022-08-11 11:46 PM
Hi Andrii,
Your right, I can create create a new zone categories and merge. But I can't create a schedule where I can show the zone "name" & "category" in same column.
I'm only going off an example shown to me, I don't know how the table was generated.
It could have been a table of text? I don't know.
Here's the best can do (please see attached).
I've also attached the example.
2022-08-12 02:11 AM
Your schedule looks good,
If you also need a subtotal of 3 zones (281.59 m2), just select the flag opposite the zone category and the Sum icon opposite area in the schedule settings.
2022-08-12 02:37 AM - edited 2022-08-12 03:17 AM
It seems the example table were generated as text, because it's not logical (at least for me).
In Archicad schedule you can have all this data (I mean subtotal) only in a different order.
2022-08-12 03:32 AM
I agree.
2022-08-12 08:11 AM
I finally did it this way, and used zones to do it, but I had to cheat a little with creating the shape of the site coverage zone, and used reno filter to control where the zones showed in which table.
2022-08-12 09:14 AM
Great !!!
