Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
ANGLED STAIR IN ARCHICAD 11
how can someone create a stair with two sections in anhle different than 90 degrees??? how can you create an angled (in plan view) stair?
I seem to find only L or U shaped stairs (sections in 90 degrees angle only).
i work in ARCHICAD 11
THANKS!
1 REPLY 1
Erika Epstein
1. In the help menu, search for
"Custom Stair Based on Manually Drawn Elements".
2. Another approach is to create separate stairs for each section if they are standard and then use a slab to create the landing
3. Create all steps and landings with slabs and/or other 3D elements
4. Use archistair by Cigraph, I believe free for students
http://www.cigraph.it/cigraph/pagetrans.do?action=current_product&prodotti_id=10&lang=en
5. Cadimage out of New Zealand has Stairbiulder; I'm not sure what their policy is for students
http://www.cadimagetools.com/tools.aspx?id=6
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
