ARCHED WINDOW WITH 10" TRIM
Is there a simple way to make a 12' wide by 5' high arched (not cemicicular) window with its own 10" exterior trim/molding.
Thanks Paul
Assuming that you are using AC9 and the standard Library (not the SE), the "W Eyebrows Fix" will do the trick. For my parameter settings I had to make the shoulder height no less than 4".
Sorry Jay, perhaps I needed to be clearer.....this is a window that the bottom sill is not a radius, actually it is several feet higher. and where is the eyebrow fix...?
Thanks, Paul
