AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
ARCHICAD 19 Update 4013 Is Available
We have released ArchiCAD 19 Update 4013. It is currently available through the automatic update system for the INT, USA, GER, AUT, BRA, CZE, FIN, GRE, HUN, NED, NOR, NZE, POL, POR, TUR language versions, other language versions will follow as soon as possible.
This Update provides an important fix to an error of ARCHICAD 19 Update build 4011: "199288: Snapping fails and causes wrong feedback and placement of elements in certain circumstances". It is not a cumulative Update, this means Update build 4011 must be applied first before applying this one.
Please also note that with this Update there will still be build number differences between components:
• The package build number (registered in the ProductVersion.xml) is 4013
• ARCHICAD.exe build number is 4013
• BIM Server build number is 4006
• BIM Server Manager is 4011
The “About ARCHICAD” splash screen will correctly display build 4013. Due to an error, License Information dialog will show build 4006.
You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-4011to4013-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
2 Replies 2
Aaron Bourgoin
the installer reports an error message when trying to install.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Aaron Bourgoin
Hi, yes I am the Admin.
it works now, Repaired Disk Permissions and re-took ownership of the ArchiCAD 19 Folder and contents.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
