We have released ArchiCAD 19 Update 4013. It is currently available through the automatic update system for the INT, USA, GER, AUT, BRA, CZE, FIN, GRE, HUN, NED, NOR, NZE, POL, POR, TUR language versions, other language versions will follow as soon as possible.
This Update provides an important fix to an error of ARCHICAD 19 Update build 4011: "199288: Snapping fails and causes wrong feedback and placement of elements in certain circumstances". It is not a cumulative Update, this means Update build 4011 must be applied first before applying this one.
Please also note that with this Update there will still be build number differences between components:
• The package build number (registered in the ProductVersion.xml) is 4013
• ARCHICAD.exe build number is 4013
• BIM Server build number is 4006
• BIM Server Manager is 4011
The “About ARCHICAD” splash screen will correctly display build 4013. Due to an error, License Information dialog will show build 4006.
You can download the Update packages from the Release Notes page here:
