mtron
ARCHICAD 19 Update 5005 Is Available
We have released ARCHICAD 19 Update 5005. This Update contains many Teamwork and BIM Server related and other improvements. It is currently available through the automatic update system for the INT, UKI, USA, AUS, NZE, GER, AUT language versions. Further language versions will be enabled as they pass Quality Control. You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-4013to5005-ReleaseNotes.html
22 Replies 22
gpowless wrote:
I updated AC19 to 5005 but the resizing open / save dialog issue is still there. Does anyone have any suggestions?
Another workaround: When "Open" or "Save" window appears, right click on the title bar, select "Size", then press right arrow and down arrow on keyboard, then move you mouse to resize.
After the update I found that AC freezes when I open the render setting dialog: I tried with different files in different mac, always with the same result. The render is generated (despite often with a full black result, as before), but I cannot change setting without having an Archicad freeze.
Has anyone had the same problem?
Giacomo
Mac Pro + OS 10.9.5
Giacomo
Mac Pro + OS 10.9.5
Thanks to Graphisoft: I got a call that helped me to solve the problem reinstalling from the original AC19 cd and the 5005 update again, and all seems to be working well!
G
