ā2021-05-27 08:35 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
ā2021-05-27 12:41 PM
ā2021-05-27 12:57 PM
Minh Nguyen
GRAPHISOFT
ā2021-05-27 01:06 PM
ā2021-05-27 01:10 PM
Minh Nguyen
GRAPHISOFT
ā2021-05-27 01:17 PM
ā2021-05-28 07:34 PM
ā2021-05-31 05:17 PM
ā2021-05-31 05:30 PM
ā2021-05-31 05:41 PM
Braza wrote:None of the above. Bit strange this one as I can create a new beam in my current project with 6001 and it fails, but in a new clean file it is ok. Even adding a new beam in the MOD fails
Most probably you did, but did you check if the beam is in multi segment mode and the segment is locked?
