‎2012-11-10
02:16 PM
‎2023-05-23
02:39 PM
Rubia Torres
‎2012-11-21 04:48 AM
David wrote:Hi David,Da_RoCk wrote:The problem is not element selection, it is maintaining that selection when using the Pet Palette to edit the element. Also, it is a problem of the same type of adjacent element getting selected when needing to edit the originally selected element.
If we want to edit, say a slab and we click on the edge, then immediately the object that overlaps it gets selected. What i would normally do to work around this is select the slab first, then select the "slab" element from the tool box on the side, and edit it from there. Correct me if i am wrong, but this restricts AC to see the active element only thus allowing you to edit the slab alone.
‎2012-11-21 02:38 PM
Da_RoCk wrote:Da_RoCk:David wrote:Hi David,Da_RoCk wrote:The problem is not element selection, it is maintaining that selection when using the Pet Palette to edit the element. Also, it is a problem of the same type of adjacent element getting selected when needing to edit the originally selected element.
Thanks for the reply. In order to maintain that selection, after you have selected that element and may it be that you are in the pet palette, i would select the element tool on the side then do the editing.
If what i understand is correct, i just encountered the same problem in what i am currently doing and it worked for us here.
Cheers
‎2012-11-23 12:30 AM
‎2012-11-23 12:32 AM
‎2012-11-23 01:14 AM
‎2013-01-16 01:21 PM
‎2013-01-16 02:16 PM
‎2013-01-16 03:07 PM
