Gus
Add camera in the middle of and existing path?
Is there a way to add a camera in the middle of and existing path when making a quicktime walk-through movie? I have only had luck adding to the end of the path, but if it's a long path and you want to change something in the middle that doesn't help.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
If you are in the 3D window of your selected camera, navigate to new position, then go to View> 3D Navigation Extras> Insert a new camera after the selected one
(This is in AC11, location of menu items may have changed in later versions)
