2013-04-18
		09:10 AM
		2023-05-23
		04:31 PM
			Rubia Torres
2013-04-18 03:08 PM
2013-04-23 04:09 AM
David wrote:David,
Probably the change is that the 2D is now scripted (2D Script) rather than drawn (2D Symbol) in the library part. You can draw in the 2D Symbol, but will need to deleteor comment out the 2D Script for the Symbol to be usedrather than the Script. You should be able to copy from the 2D View to the 2D Symbol to get started. For objects with a 3D component, you will need to confirm that the 2D and 3D locations match.
2013-04-23 02:32 PM
Rian wrote:This adds a "!" to the line, so it is not executed by the interpreter. In the Help files see:or comment out the 2D Script for the Symbol to be used
Rian wrote:Since the 2D Symbol can be drawn independent of the 3D model, its is possible that the symbol and model do not match. One way to confirm is to check the 2D position in plan, the set the 3D window to Parallel Projection Setting > Top View and see if the model is in the same location.you will need to confirm that the 2D and 3D locations match.
2013-04-24 03:53 AM
