After SEO it's still one object...???
Hi
I've got a wall that I want to perform SEO on to split it into several pieces using some curved beams I've made in trussmaker. However when I use SEO it is still a single object.
Any way round this?
TIA
Adri
SEOs do not create more elements, they only create relationships between elements. You can split a wall vertically with either the split command (edit menu) or by just adding nodes (pet palette). What might work depends on what you want to do with the walls. You will need to be more specific.
