Angled Columns
Hello,
how do I create columns other than 90 degrees to the slab.
Any help would be appreciated.
Regards.
Shanek.
4 Replies 4
hello Shanek
Which type of columns in which version of AC?
You have some library objects which may solve your problem.
You may also see this topics where some solution where "linked". http://archicad-talk.graphisoft.com/viewtopic.php?t=6944
You may also use the "search" fonction of this forum which certainly give you some other solutions. This forum is a golden mine if you take time for searching.
Hope this helps.
do i require to know gdl?
Not obligatorily
You have some angled columns in AC Library. May one can solve your problem without using GDL.
TDabney
You could also try using the roof tool.
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
