Angled Staircase - Best Workflow
What is the best way to model an angled staircase please?
I.e. the flights are standard but the landing is at an angle (a variation of an L-shaped stair with a wedge shaped landing)
11 REPLIES 11
No I kept getting that as well.
I am not sure if moving the end of the first line and start of the curve has any impact.
Also I found I had to flatten the curve a bit as a full arc was giving an error and wouldn't allow the stair to be created.
Thanks for letting me know Barry, this is going to annoy the hell out of me!
I've checked the fill (drawn by ANOther) and changed it so that it should work for 250 treads i.e. the length of the lines for the stair path are multiples of 250mm and the fill corresponds with that.
Attached is the dialogue and image for when I go to create my stair.
Stair, slab, stair it is for now then
