Arc a group of objects
I am trying to create a curve for a pavement line and need help on how to achieve this.
I have created a vertical line of small slabs to represent cobbles as a path edging, but need to curve the edging towards the top. Is it a case of placing each slab separately rotating slightly each time? Or is there an easy way to do this?
Any help would be much appreciated.
Aussie John
im not sure exactly what you are trying to do but can you use the multiply command using the rotate option
Cheers John
[/size]
Djordje
A screen shot would help us a lot to understand exactly what you want to do?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
