Arched, verticle railing
I need to match the verticle railing on a project with an arched (radial) railing but I am having no luck finding an existing railing type I can manipulate. Will it be necessary to create the radial railing bit by bit or am I missing something? Again?
4 Replies 4
is the library object 'building structures>fences and railings>railing vert arched' what you want?
bill
Link
You should be able to match up most (if not all) ArchiStair railings, by using the object tool and accessing the parts in the Object Library 9.pla>03 Concrete>StairMaker Handrails 9 folder.
Don't ask me why they are under the Concrete Folder!
Link.
Yes, I got it. And, as always, I was missing something. I have to admit, I am trying to finish my first all-archicad project and frankly, the construction doculment phase with this program is frustrating me almost to the point of strangling my computer. Deadlines and new programs do not mix.
I know about that all too well, and it's even worse when you're trying to pick up where a sloppy worky left off
