ArchiCAD 14 - Text Bug... cursor jumps!
Does anyone out there have this problem? I know my office does! When editing text, the cursor will jump while in mid-type. Any advice or tips on how to correct this problem. I've downloaded the most recent HotFix but no luck.
28 REPLIES 28
Tried again with the folders. Still no problem. I only put in just enough dummy layouts to do the test. Perhaps it has to do with how heavily loaded the set it.
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
I am willing to offer an ArchiCAD T-shirt to anyone who can reliably repeat this bug with a text placed on the floor plan. I have seen this bug myself, I was even able to capture it in a movie, but I have tried several times since, and can't repeat it for the life of me. You have to have a wrapped text and then start entering new text at the beginning of the text, but there is something else to it. The developers are aware of this problem, but can't track it down, until we can reliably repeat this.
Note that many other Mac text problems are caused by the fact that ArchiCAD 14 uses a new text engine - we had no choice but to implement the Core Text engine, which all other current Mac apps use. Check out this article:
http://archicadwiki.com/Bugs/MacTextProblems
Gergely Kmethy
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Wait a minute, I just checked the status of this bug, and a guy at QC figured this out: it has to do with the zoom level and the text size. It happens at certain zoom levels with certain font size.
We'll keep the t-shirt, but this will get fixed.
Gergely Kmethy
vfrontiers
Nice work on the text box deal...
BTW... is this new FONT system a step in the right direction from apple? I've yet to see the benefit. (I'm sure it's there, but I can't find it)...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers wrote:
The Navigator, on the other hand, is EVERY TIME...
1. Open Navigator and open a folder and select a LAYOUT (actually make it the current layout / bold letters, etc.)
2. Scroll the Navigator so that the previously selected layout no longer appears in the window of the navigator..
3. Try to double click any folder or layout in the current navi-window.
4. The navigator will jump to display the current layout in the navi-window and your 2nd click will be on something else...
No problems here (Windows machine though) and I have quite a long list of layout pages.
Double clicking a layout opens that layout and double clicking a folder just expands the folder.
Have you tried on other machines yourself with the same result?
vfrontiers wrote:
Ok... Thanks Matthew...I did explain it wrong (cuz that's the way my memory is these days)...
1. Open up navigator palette
2. Select any layout that's INSIDE a folder... It does not need to be the current...
3. Close the folder
4. Select a different folder and the folder containing the selected layout will POP open...
I'm trying to attach my .mov from snapz....
Nope - definintely doesn't happen like your movie.
vfrontiers
I don't mean to always accuse Teamwork, but are either of you testing in a TEAMWORK environment?
Duane
Visual Frontiers
No - solo project.
I have never used teamwork (no need for me) but it does sound like there are still a few glitches in it.
Achille Pavlidis
3. Close the folder
I get EXACTLY THE SAME, as seen on your clip. It happens in TW, i DOES NOT happen in solo projects.
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
