ArchiCAD 14 announced
17 REPLIES 17
Yes here it is, certainty upgrade, which was not fully surprising.
Yes this is more than surprising.
laszlonagy wrote:
The press release:
http://www.graphisoft.com/community/press_zone/archicad-14-announce.html
The product main page:
http://www.graphisoft.com/products/archicad/index.html
The most shameful upgrade ever. Not worth it.
Aaron Bourgoin
dat_architect:
i'm so glad I stayed up to read your post. Most helpful. Thanks for that. I'm off to jump off a bridge now. Good-bye cruel world!
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-6000 USA
Rhino 8 Mac
MacOS 14.6.1
plz, dont think that you will jump alone . . . i'm with you, too
Revit is something that i will try...i will use AC13 till i get in touch with Revitos and then good bye muchachos, at the end its only software...its a tool and why don't try something other and then see what tool is right for my job...
archicad 14 at this moment will not improve my modeling posibilitys, i will still have problem to draw a stair, custom shape of a wall without long workarounds, cut, rotate, bend, extrude, folow trough the path of solids which i cant draw in archicad etc etc etc I will lose time on same things as years before and thats too much for me
i wish that i can say Bravo GS but this is hard miss update in my opinion
Aaron wrote:
dat_architect:
Please don't, it's just a software, there are more valuable things of life than BIM.
_Salmon
I only want to say congratulations to GS Team for this effort and I encourage them to remain one step ahead as usual..
thank you Guys!!
Since AC6
Win10pro / Intel Xeon E5-1650v4 / 128Gb DDR4 2400 MHz ECC REG / NVIDIA GeForce GTX 1080 / SSD Toshiba 512GB M.2
andrewzarb
Oh boy! I've read a lot of negative comments about ArchiCAD14.
For me, I'm glad that the late release of 13 wasn't used as an excuse to move the upgrade cycle to later in the year. Congratulations GS for bringing the release back on track.
I'm already excited about these features:
- Direct Revit® MEP/Structure Link
- Reference-model Version Tracking
- Core Setting of Load-Bearing Elements
I've already been exchanging files with our engineer all improvements and the ability to only import the changes is great for productivity.
- Teamwork "Pack & Go"
Makes internet based Teamwork truly viable
- Shadows in Open GL
A long standing wish (ever since openGL was introduced)
- Import Surveyor's Data as Mesh
I've worked on projects where whole days have been spent on meshes of topography, essentially duplicating existing information.
And then there are these, I don't know how good they are but I'm prepared to be surprised.
- 64bit Mac version (of BIM server not ArchiCAD)
- Expanded Find & Select Criteria
- Easy Offset Functionality
- Layout Book Improvements
- Revisioning of Published Items
- Improved PDF Output
- Library Management Improvements
- New & Redesigned Library Parts
Brett Brown
andrewzarb wrote:
64bit Mac version
Perhaps someone in the know can confirm this. New features only say 64-bit BIM Server on MacOS.
owen
Brett wrote:
andrewzarb wrote:
64bit Mac version
Anyone who would know is still under NDA .. as with previous releases if it hasn't been announced by Graphisoft then you can't talk about it until the NDA is lifted AFAIK.
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
