ArchiCAD 16 Parallel Projection Problem
While using ArchiCAD 16, I have been using Parallel Projections to render elevation views of my project. Occasionally, in the 3D window, the model will suddenly disappear. Elements are still selectable, and even show an outline as if they are selected, but all elements have disappeared into the background. Has anyone else run into this issue?
Same here; for me it started after I installed hotfix 3.
experiencing the same problem.
Started a different thread here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=41706
