AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
ArchiCAD 17 Hotfix Build 8000 Available
We have released ArchiCAD 17 Hotfix Build 8000. It is currently available through the automatic update system for the INT, USA, AUS, NZE, GER, AUT, ITA, NED, POL, SWE language versions. Further language versions will be enabled as they pass Quality Control. You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC17/AC17-6004to8000-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
it seems this hotfix has disabled the ability to publish drawings as a DWG the only choices I seem to have now are BIMx or PDF. I can save individual drawings as DWG but not the entire layouts from the publisher as one DWG file
Sorry I spoke to soon I finally got it to work
