ArchiCAD 8.1 R2/V2 update patch now available
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Dear Talkers,
The ArchiCAD 8.1 R2/V2 update patch for the International English version is available to download. Other language versions will be uploaded continuously. For details please visit:
http://www.graphisoft.com/support/archicad/downloads/ac_maintenance_releases/
Sincerely,
Gergely Kmethy
Gergely Kmethy
100 REPLIES 100
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
~/archiben wrote:
could i ask (politely!) why the mac patches have been pulled?
~/archiben
I hope to find out soon too.
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
I have just installed AC81-R2-2256-USA. Does that take care of all the previous problems, or is it necessary to ALSO install AC81-R1-1410-USA?
Cathy
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
"AC81-R2-2256-USA"
is the latest Build for the Windows version of AC 8.1 (no other Updaters after are needed).
1410 was the old updater (which is updated by AC81-R2-2256-USA).
Jeffry Covarrubias
Erika Epstein
HI
I installed r2 yesterday, both parts, and had some severe problems with how it generated building elevations. I sent a file to Jeffry at tech support.In addition to some of the exterior walls not showing, every elevation had its own unique feature. One distorted a custom library part making it huge and about 100 feet from the original plan location, but showed it correctly in other elevations, another had not only the miserable south elvation but a fit in window shoed a bonus north/south building section perpendicular to it about 2000 feet above!
Go figure.
I was able to reopen that file successfully after reinstalling 8.1r1+ but do archive before playing.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
aahatimo
erika,
pretty strange behavior! i guess i am fortunate.
there are also some pm3 import troubles also. see this thread: http://archicad-talk.graphisoft.com/viewtopic.php?p=11133#11133
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
The new Mac version of V2/R2 is on the http://tr.graphisoftus.com/ site. I could down load the 1 of 2 (30.7 MB) but 2 of 2 (79.9 MB) links to an unknown location?!
Any ideas?
Thanks,
Joseph Harouni
aahatimo
looks like 2256 us for windows & mac has been pulled from the tr gs us site. maybe a fixed version will appear soon. why is there no message
but, there is a 2256 build on the updates page w/ todays date, and link to same libraries..
< * ArchiCAD Update Patch
Sub release: R2/v2
Release Notes
Last modified: 2004-03-30
International version:
Windows: AC81-R2-2256-INT.zip (21,6 MB)
For those having downloaded this Mac updater between 23-03-2004 and 26-03-2004. Please go here
US version:
Windows: AC81-R2-2256-USA.zip (21,7 MB)
Other localised versions are coming soon!>
ok, gs, what is up???
tim hanagan
SeaGeoff
Ace
I had the same thing happen then when I went back to the site everything had been pulled, Mac and Windows alike. Appears a little more work is needed on these.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
aahatimo
duh, i usually save a copy of current ac.exe build before i do the upgrade. guess i better get back in that habit!
the updater posted will not reupdate 2256, guess its total reinstall time.
grant noel did get back up and running w/ a total deinstall/gs cleaner/reinstall/update. i may wait till we hear SOMETHING from gs.
tim hanagan
Aaron Bourgoin
Check the tr site now. Apparently the Mac problem had to do with crashing when trying to post files to an ftp site. A second patch to correct this is available along with the application and library installers.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
