ArchiCAD 8.1 R2/V2 update patch now available
Greg Kmethy
Dear Talkers,
The ArchiCAD 8.1 R2/V2 update patch for the International English version is available to download. Other language versions will be uploaded continuously. For details please visit:
http://www.graphisoft.com/support/archicad/downloads/ac_maintenance_releases/
Sincerely,
Gergely Kmethy
Gergely Kmethy
VP, Customer Success, Graphisoft
100 REPLIES 100
aahatimo
Aaron wrote:
Check the tr site now.
it was pulled about an hour ago, at least on my browsers. only the 1410 builds show up.
i imagine gs is working on getting new builds out.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Will someone from GS please verify that 2256 is not to be used and to revert back to the previous version.
I Lost a total of about 8 hours trying to figure out what was wrong, uninstalling, reinstalling, etc.
I now have 2256 running but it has been deleted from the Graphisoft US website.
Do I now need to uninstall once again and download and reinstall 1410.
Thanks, Grant
JCovarrubias
TR is all set now. Thanks for your patience.
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
JCovarrubias
Thanks, Grant
You can go from the 8.1 (CD-version) to the 2256 update.
Jeffry Covarrubias
aahatimo
jeffry,
could you be a bit more specific? what do we early updaters need to do to be able to update drawings in pm3.1r2?
do we need to do a full deinstall & registry cleaner/ reinstall then update.
is this a revised 256 build? if so why the same build#?
a bit more timely info on the tr site may be helpful in the future when a build is pulled.
thanks!
tim hanagan
JCovarrubias
aahatimo wrote:
jeffry,
thanks!
as per the website:
If you have already downloaded and installed the 8.1 V2 Mac Updaters from March 26, 2004-March 29, 2004 ([30MB] and [75MB] files), you will only need a mini-update known as DGLib [380KB] (version 2.0.0.0 v2 (1535/2267)). This mini-update fixes a bug that caused ArchiCAD to crash when uploading to an FTP site with Publisher on Mac.
To install this mini-update: download DGLib [380KB] (version 2.0.0.0 v2 (1535/2267)) and replace the existing DGlib file (in your Applications\ArchiCAD 8.1 folder which is version 2.0.0.0 v2 (1523/2256)).
Jeffry Covarrubias
aahatimo
jeffry,
that is a great explanation for the MAC os updaters.
i was asking for the specific pc update procedure to correct the pm3 import /update problem both grant & i were having. background archicad refuses to open.
both pc & osx builds were pulled from the site yesterday. the explanation you give was already on tr prior to being pulled.
i have been waiting since yesterday for info. i have done substantial work using the 2254 build & now i cannot update / import into pm3.1r2. how can this be expressed more clearly.
is gs going to address this issue? are we merely beta testers?
sorry to be so blunt, i just expected better response from gs on this matter.
tim hanagan
JCovarrubias
As far as your problem is concerned, could it be a file-specific issue?
Out the many requests we receive per day, no one is reporting problems like yours at this time (who have upgraded to 2256). I would like to handle your case personally so please contact me via our toll-free tech support number 800-238-3992.
Jeffry Covarrubias
aahatimo
thanks jeffry, i will give you a call.
tim hanagan
Erika Epstein
I have had some wierd problems after installing r2( I did post this elsewhere on the forum). Jeffry confirmed problems with AC's curtain wall library part. This problem occurs with and without the library updater. I never made it to plotmaker, but given the problems he confimed I am having I am back to 8.1+ until he hears from Budapest.
I already miss the increased speed of r2!!!!
I already miss the SEO working much better!!!!
If only it could generate an elevation correctly.
Sigh.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
