ArchiCAD 8.1 R2/V2 update patch now available
Greg Kmethy
Dear Talkers,
The ArchiCAD 8.1 R2/V2 update patch for the International English version is available to download. Other language versions will be uploaded continuously. For details please visit:
http://www.graphisoft.com/support/archicad/downloads/ac_maintenance_releases/
Sincerely,
Gergely Kmethy
Gergely Kmethy
VP, Customer Success, Graphisoft
100 REPLIES 100
aahatimo
stubbornness is not always a virtue:
i have successfully downgraded to 1410. my 2256 files somehow open fine in ac8.1r1 and bg archicad operates correctly in pm3.1r1. there still was the locked file message regarding gsshellx.dll, but it shows a lower build # 3.0.0.353.
erika, are you running 1410 now?
in the meanwhile i may consider to upgrade my notebook to a new 7200 rpm 60 gig hard drives http://www.hitachigst.com/hdd/travel/tre7k60.htm to replace my 2+ yr old 20 gig 4200 rpm. i believe my os may be corrupted.
thanks for everyone's assistance, this forum is great! i also appreciate david t. & jerry c. from gsus persistance.
tim
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Erika Epstein
Tim,
Yes I am back on 1410 and successfully working as before the r2 "incident". I don't know about you, but Jeffry advised me to not open any other files in r2 and to go back to 1410 until budapest or he gets back to me. AC and plotmaker working fine.
Regarding your hard drive, it may just be to full. I try to keep mine no more than half full and the project one is an 80 gig. Someone else can probably tell you more specifically the point at which the lack of unused space not available for extra temp file use becomes detrimental.
On windows programs ( as I understand it) the OS more or less automatically uses this space. If I am not mistaken, on the mac side you have to set it. Probably got this part wrong so someone please chime in.
Erika
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Guys,
This must be a US version thing as my International R2 is zooming along ...
Was not wrong in the times of OS9 ... now the management is more or less the same - leave the OS to do it.
20gig, especially if more than half full, is not enough for 8.x; the other day I got 2.5GB swap file (!) with 80GB drive and 1GB RAM on XP. What a crawl that was ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
SeaGeoff
Ace
All the updaters ran without a hitch for me as well but I haven't tested a PM link yet. I did notice a couple things:
Have you managed to migrate your keyboard shortcuts? Swapping the preference files as before doesn't seem to work. And have you or anyone else noticed that the library update is missing the RoofMaker Library? I found this to be true with both the updater from the US Tech site and the GS main site, the US library in both cases.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
I gave up after trying about three different ways. It's very strange; the prefs copy OK, but have no effect.
I have successfully overwritten v2 lasting.prefs with v2 lasting.prefs, so it's only one do-over per office if you have standardized shortcuts.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Erika Epstein
"Djordje" wrote:
Guys,
Oooh, I'm jealous!
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Rick Thompson
2 things
Anyone else crashing if they save with something selected? This might not always happen, but several times as I save... example - just in case the section I am deleting is the wrong one, AC crashes (build 2256)... big help to save.
I moved preference to a new computer, and now I am warned that add-ons are missing. It is the "check doubles" add-on, and it is actually there, but also listed as "not found" (so twice), and it want let me remove it. Any suggestions, maybe which preference stores those?
thanks
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
JCovarrubias
Erika wrote:
Tim,
Erika
Hi Erika:
Yes - your problems are file-related. I did advise using 1410 until I hear back from GS development.
I'm not working on Tim's case at all but it sounds like a system-related problem.
Tim's problem and your problem are not related. Problems did arise after the 2256 (coincidental).
j.
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
SeaGeoff
Ace
Jeffry,
It’s good to see that you’re monitoring this. Can you please look into the keyboard shortcut issue. Thanks.
Regards,
Geoff Briggs
I just had a weird thing happen to my linetypes when taking a PM 3.1 R2/2256 LBK back to R1 for printing.
I had worked on a project in my office with 2256 and got a LBK ready to print a few revised sheets. Came to my friend's office which is still running R1+ and all of my dashed lines were solid! (Of course, I didn't notice until I had plotted )
Just updating the drawings got the correct linetypes back. But strange, nonetheless.
I haven't experienced any of the crashes or other behaviors mentioned here though.
