2004-03-24 03:25 PM
2004-05-02 08:42 PM
Karl wrote:I use the detail tool extensively. Probably why I panicked when I thought it wasn't working. It's great not only for details but also enlarged plans. Like you I drag a copy as for an unlinked section. I find using the detail tool for enlarged plans also eliminates the need for an extra set of layers for them.
I just copy all of the detail to the right (like an unlinked section - so rebuild won't bring back what I delete/etc). I confess, I've only used the Detail tool for half a dozen "real" details so far, so my experience is pretty minimal here!
2004-06-21 10:11 PM
2004-06-22 12:20 AM
2004-06-22 03:29 AM
repaired permissionsSounds like you want me to get out and clean my warp coils as well.
cleaned your caches
ran the cron scripts
updated the prebinding
2004-06-22 05:43 AM
another Moderator
2004-06-22 10:47 AM
tsturm wrote:and check the dipstick.
2004-06-23 03:33 AM
2004-06-23 05:20 AM
2004-06-23 06:18 AM
I did not find this in the documentation on the Mac update list site.From
Does this mean that OS 10.3.4 runs the crons at start-up
or only at wake-up ?
What cron routines are run ?
Addresses an issue in which scheduled items, such as automated backups or Software Update checks, may not work if the computer is asleep at the scheduled time. With this update, the schedule will run once the computer wakes from sleep.The only difference between Onyx and Coctail is price. I have been using Onyx for the past 6 months without problems.
another Moderator
2004-06-23 10:43 AM
tsturm wrote:this was exactly my point: installers and the like that mess with the system library permissions slow the
I am sure that this R2C version operations around its own environment better. How does it perform when you ask it to open a file from a remote machine? How fast is it when you need to look for a picture to use in your drawings? This is where I am having my machine SLOW down.
Could it be that the server we have is still running OSX 10.2.8 and all the other machines are running 10.3.4?no - that's exactly the same setup as us.
Is there a difference between Onyx and Cocktail, besides a cost?i've never used this 'onyx' app, but you can give 'cocktail' a go without paying up front. if you do decide to try it: click the 'pilot' tab along the top, check everything except 'repair permissions' (i always prefer apple's apps to handle this even if they do get their permission information from the same file) and then hit the 'run' button. you may want to check in the options tab first if you don't want to lose safari's cache and favicons . . .
