Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
ArchiCAD 9 Hotfix-3 is now available
Dear ArchiCAD-Talkers,
The third hotfix patch (build 2045) for ArchiCAD 9 is now available. Go to the 'Help' menu of ArchiCAD 9 and click on the command 'Check for updates...' This patch can be applied to all previous versions of ArchiCAD 9. For more info please click on the URL below...
http://www.graphisoft.com/support/archicad/
Gergely Kmethy
20 Replies 20
Aussie John
STILL doesnt fix the plotmaker command 'go to "drawing name" in Archicad'. It goes to Archicad OK just not to the quickview in question.
This command has been broken and reported for several of the last releases. I've lost count!
Common GS this cant be that hard to fix!!!!!
This is a really useful command as it saves having to search through the quickview list in Archicad for a detail that is hidden somewhere and you cant find.
Cheers John
[/size]
