Greg Kmethy
ArchiCAD 9 Hotfix now available
Dear Talkers,
We have released a hotfix for ArchiCAD 9. It supports most of the existing language versions. For details, please read announcement here:
http://www.graphisoft.com/support/archicad/
To acquire the hotfix, go to 'Help' menu of ArchiCAD and click 'Check for updates...'
Gergely Kmethy
VP, Customer Success, Graphisoft
23 Replies 23
Aussie John
R wrote:
I just ran the update in the help menu and updated Archicad 9 now it will not start up. It gives me an error message:
Application Launch Failure
The application "ArchiCAD" could not be launched because of a shared library error: "T<ArchiCAD><ArchiCAD><ElementManagerLib><IsInMarki__Q23EDB11GeneralElemCFPC7SelTypes>"
The error code probably gives it away but you should say what your system is. Most people add it to the bottom of your signature ( go to profile)
Have you read the previous posts indicating where problems might lie. If you are using a Mac and have multiple copies of the application in your folder could cause a problem or changing the filepath of the original installation.
You might need to reinstall and redo the process.
Cheers John
[/size]
Ed_Brown
I am fairly sure R.Fry bumped against the authorization problem.
Check if there is Log.txt file in the ArchiCAD folder (where the .exe is) and it contains a line similar to the below line:
"ServiceException: (error code = -30008; message = "The trust relationship between this workstation and the primary domain failed."
This is the tell-tale sign that the the java installer is failing due to an authorization problem (not connected to network/network domain changed since original install). Follow the instructions that I gave earlier for laptop not connected.
Ed Brown
Graphisoft Technical Support
Thanks for the help.
I do have older versions of Archicad installed - don't know if that gave me the problem. Uninstalled and reinstalled Arch9 then ran the update and everything came out fine though i forgot to save my preferences/shortcuts. Thought i'd chosen to save preferences in the uninstall dialog but it seems they were deleted.
Rakela Raul
2nd hotfix now available
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
