ArchiCAD 9 Polyline offset bug?
I drew a simple polyline in AC 9 and tried to copy an offset (nothing selected-polyline tool active-offset active-magic wand existing polyline-specify offset).
Sometimes (i think depending on the screendistance) nothing seems to have happened. But if I do undo and redo the hotspots of the offset polyline appear (polyline itself not) if I change the view (zoom) the "invisible" polyline appears.
Is this a known bug?
Hielke
3 Replies 3
Sorry, forgot to mention it was a single (one segment) straight polyline.
Ben Odonnell
Hielke,
Same problem here. Although it is there. Just do a pan or a zoom and it will show up.
But yes it does seem to be some re-draw bug.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
There is another.
If you unify linear elements into a polyline, and if they are not all drawn in the same direction, the offset results, especially walls, can be quite spectacular ... and usually are closed polygon.
Reported.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
