2013-08-30 04:22 PM
2013-08-30 05:25 PM
another Moderator
2013-09-02 02:34 AM
2013-09-03 09:10 AM
rwallis wrote:As attaching USB keys to virtual computers is not always easy or possible. In situations where this cannot be solved we usually recommend using USB to ethernet HUBs. Many clients of ours have good experience with that.
- Your license 'key' must be plugged in - presumably at the server end?
2013-09-06 08:51 PM
2013-09-25 12:54 PM
belly917 wrote:Phil, from GRAPHISOFT side, what I can surely answer:
Thank you everybody for your feedback.
As of right now, we're no longer considering going with advance2000. When we asked a couple dozen specific questions, they continued to use loose marketing terms instead of the hard details we were looking for.
The death knell was their response to 2 questions concerning archicad - How do you get Archicad to run under remote desktop environments? (standalone versions will not) and There are reports that the 3D view crashes in a virtualized environment. Can you test for this?
There response was "we've gotten revit and autocad to work, we'll figure it out"
So we're done, thanks again for all the responses.
Phil
2013-09-25 03:26 PM
another Moderator
2013-09-25 07:18 PM
2013-09-25 07:27 PM
another Moderator
