ArchiCad 6.5 and Window Cills
I`ve returned to ArchiCad recently though I haven`t upgraded from my version 6.5. Window cills (uk standard) in ArchiCad 6.5 were always a problem and I assisted Theometric in developing their cills. I`d be interested in knowing if it possible to get a window with a concrete cill outside and timber cill inside that is parametric.
You'll have to upgrade to version 9 for this feature. (see pdf attached)
It features both outside and inside cills, and doesnt restrict the height of the cill can be like in earlier versions.
Lennox, thanks for the pdf. it looks like they`ve solved the problem which always was an issue in the past. My ArchiCad seller gave me a really good window object when I bought 6.5 which addressed the problem fairly well but it had flaws in 3d mode.
