‎2010-03-12 08:11 PM
‎2010-04-20 09:35 PM
Krippahl wrote:Not that I know. No.
Good to hear from you Henrique, and thanks for your clarification.
While we are on the subject, can you tell us if there is some work being done in Portugal to implement BIM mandatory usage? The DWF sure was a bold step, but it falls short of realizing the whole digital potential, and seems to be at least a decade behind (better late than never, but why not aim higher?)
And if so, who is involved?
Thanks a lot
‎2010-04-20 09:37 PM
Krippahl wrote:You don't need BootCamp. Try this: http://www.parallels.com/eu/products/desktop/. Cheaper then a home printer.Matthew wrote:Albeit some the-sky-is-falling alleged Portuguese architects that have been posting here, the DWF format is only asked on some towns.
The situation in Portugal is particularly worrying. It seems that it is easily fixed since DWF is an open and documented standard, but it isn't clear yet if GS is taking this seriously.
Not wanting to excuse GS for not having provided a quick solution (I know they are working on it, but we are after all a small market), the solution is quite simple: Bootcamp, Windows, DWF converter.
Bootcamp is free, Windows is a must if you are serious about your work (there are so many programs that only run on windows, even with ArchiCAD), and the DWF is also free.
Not a major investment, and certainly not in the same league as demanding Revit models. That would, at the present state of the art, simply trash ArchiCAD.
‎2010-04-22 07:31 PM
‎2010-04-22 10:59 PM
matjashka wrote:So translate via IFC and send them the Revit file. They'll probably never even open it.
We tried to get into doing work for Chicago Public Schools. Our understanding is that they chose to require information specifically in REVIT format, for archives (as if any proprietary data format ever worked in a long haul).
Great lobbying, Autodesk.
‎2010-04-22 11:52 PM
‎2010-04-23 09:38 PM
matjashka wrote:Based on my experience I don't think they have a clue what they want it for. They've just been hearing all about this BIM stuff and figure it would be a good idea to have the files.
What they would use it for, is my educated guess.
I would think that typically you can't just take somebody else's source file (but that's what waivers are for), add a few walls and dimensions and have a project for an addition ready for permit. But this is what one does with original, old construction blueprints, when used as backgrounds for redevelopment.
Could be that somebody wanted to do it the smart way and assumed that Revit was the most progressive data format.
