Thank you Zigurds for your considered reply.
I must admit that at first I thought that we might be talking slightly at cross purposes. But having followed the link you provided, I stand corrected.
Your perspective of the matter is somewhat broader than mine, but I now appreciate that what I was seeking to ask was how well Ecotect (or an other software solution) integrated with ArchiCAD to provide easily interpreted visual feedback particularly at detail levels 100-300.
Perhaps if I give you some more information I will make myself clearer: Having graduated from a university that had a strong emphasis on building performance (thermal/lighting/structure/etc) I felt that my appreciation of these aspects of building performance was acceptable. However, in professional practise, any detailed building performance analysis is only performed at the later stages of a project design, and even then only if the project size & budget is deemed to warrant the expenditure of the 'extra' time & money!
Whilst I received a good grounding in the calculation of lighting & thermal performance, it is far too laborious & time consuming to carry out such calculations manually, particularly for the majority of our work whose budget would not support it. As with all the architects I have encountered, our designs take form from an intuitive/past-experience appreciation/application of thermal/lighting principles.
However, with the welcome current emphasis on more performant buildings (and houses/flats in particular in our case) I would greatly appreciate a software solution that is (and will remain) 'seamlessly' integrated with ArchiCAD that provides a rapid graphic feedback on design from the early stages. For example:
Initial design form: (levels 100-300)
- analyse sun shadows, wind modelling, internal natural daylight levels of at different times of day/year at any geographic location.
- Assuming given wall/floor/roof/window constructions/performance estimate building heat loss (to gauge against mandatory requirements).
- Auto, or one-step, update of this analysis following modifications to the BIM
- Idealy the software is sufficiently integrated so that once certain parameters are set-up (component U-values for example) the building analysis can follow in real time: In the same way that when a wall is moved on the AC floor plan, the change is reflected in the section/elevation/3D windows, then that same modification of the wall in the AC floor plan is updated in the thermal/daylighting/wind analysis windows & reports...
Detailed design: (levels 300-500)
- As the design is refined the thermal/lighting model follows seamlessly:
- Construction elements are specified in greater detail & their performance parameters are updated
- As the design evolves the effects of each and every change in the BIM can be (almost) instantly gauged in the graphic/numeric feedback from the building performance software (made possible by recent multi-core, multi-threading, 64 bit hardware & Operating systems with access to large amounts of RAM).
My understanding is that such integration is not yet available, but it must surely be a high priority objective for any BIM software provider that wishes to steal a huge advantage in the current market place...
Furthermore, since most architects/designers are graphically orientated, a graphical interface following Ecotect's lead would appear (at least to me) to be essential.
When I finally find the time (and courage) I shall try out Ecotect, but it is far from straight forward since the software is windows only.......
Meanwhile, do you find yourself always using Ecotect at the very early design stages to assess window layout & form, room depth, building layout on the site, etc, or is it still too cumbersome to be used for each project? And, thank you again for your time.
AC30. Twinmotion. M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 27 Golden Gate
