ArchiStair for AC10
Hi
Did someone try this plugin in AC10? I downloaded new demo version from Cigraph, but it seems not working at all. When I pick up archistair palette (archistair library is loaded) and create stairs, after last OK nothing happens. I tried this plugin in AC9 formerly and it worked fine. In addition all others Cigraph plugins are working.
Any idea here?
Roman
13 Replies 13
rgarand
I have just tried to use the upgraded ArchiStair with the same problem as above. I have entered in the unlock code and everything correctly. ArchiStair seems to function as a demo.
The only thing that is a bit weird is when I click on Design Extras>ArchiStair>Info I get a dialog box which tells me my unlock code is invalid. I then select the correct unlock code and it automatically selects the usb key number associated with the unlock code. All of which are correct. ArchiStair still does not work.
Another problem,
I am trying to develop a custom stair, when I select my 3 simple fills I get an error message:
There is at least one fill not connected to the others.
I have redrawn all of my fills and realigned them.
Any thoughts?
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Dear Garand,
first of all I suggest you to download the latest update from our www.cigraph.com web site.
Please don't care about the version (we didn't change it) but about the date of upload (the right one is july 03 2006).
Then delete the preferences files from the Shared Document folder (look at my previous posts) then start ArchiCAD & serialize again ArchiStair.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
rgarand
Fabrizio,
I have downloaded the latest update and installed per your email. All works fine...except I still cannot select 3 fills to create a simple custom stair. I still get the error message:
Any thoughts?
Robert J. Garand
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
the only solution is to send me the pln file (please not an archive) including just the 3 fills plus two hotspots indicating where you are clicking...
friendly
Fabrizio
Fabrizio Diodati
