Brett Brown
Archicad 12 Organizer
The Organizer moveable divider, why doesn't it remember its position?
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
10 Replies 10
aahatimo
noticed the same thing w/ library parts window.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Eduardo Rolon
Bug that has not been squashed since the Beta.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Rakela Raul
eduardo: do you still need ac12 thru ac9 ?? maybe you rt because of the vanished Ductwork........bad sign on a software....just a thought
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Thomas Holm
Rakela,
I also have all those versions installed along wtih 8.1 and 7. If I have to open some old project for a quick fix, I find it easier to do it in saved version than to migrate. For more than the hour-long fix, I migrate. AC12's speed is worth the trouble!
Eduardo Rolon
Same reason as Tom's + since I retired my PPC G5 I kept a Copy of AC9 if I need it sometime in the future. Also since I help Jon (3DCadCo) down here sometimes I get tech support calls and it helps having the specific release. FWIW I did uninstall 8.1
AC29 US/INT -> AC08
another Moderator
Rakela Raul
I see !!! libs are a nitemare to me. thanku all
Thomas Holm
I'd say, that's a courageous move!
I need to exchange various AC files with other AC users that are not that fond of upgrading to the latest versions.
As everybody has his mouth full of the latest dwg conversion, IFC format, etc. ... I still struggle to transfer AC files between the same community : AC12 to AC10, AC11 to 9 or 8, ..., uploading AC9 file and send back for revision,...
No automatic translator available by GS, don't want to start downgrading step by step... that's the point of having multiple versions installed...
Stress Co_
Humm.
Works for me. Library parts (object settings window?) too.
Marc Corney, Architect
Red Canoe Architecture, P. A.
