2010-05-10 05:56 PM
2010-05-15 01:31 AM
Achille wrote:There are not many Intel Macs incapable of running 64-bit. By August 2007, all shipping Macs were 64-bit capable.
We alredy had to get rid of G5 mac because of AC13, now we will be forced to ditch all non-64 bit Intells for AC 15?
2010-05-15 01:52 AM
Ralph wrote:Yes only the earliest laptop processors were 32-Bit .. AFAIK Mac Intel desktop processors have all been 64-bit?Achille wrote:There are not many Intel Macs incapable of running 64-bit. By August 2007, all shipping Macs were 64-bit capable.
2010-05-15 02:11 AM
sinceV6 wrote:Agree 100% .. Great post in general but excellent summary of the major areas Graphisoft needs to address.
If GS wants to improve AC, in my opinion they should look into:
1. Database parametric engine: In Revit, you really have live views of a single database. If you have several views open and select a door in one of them, it gets selected in other views, and changes are realtime. In AC, you may have a plan view and a section view opem, but they are not live and connected, and get updated only after you click on the other view. Even worse: AC bases almost everything on the floor plan, so while in Revit you click in a section view and the software responds like "the user selected a door", AC works like "the user has clicked a point in a section view, in the coordinate x=2 y=1.8, which based on the floor plan and elevation data, corresponds to an area enclosed by a door, so, the user has clicked on a door: select it".
2. Remove the 80's thinking about software: if sketchup and revit can make components and families without programming knowledge, why AC can't do it?
3. Improve the model->view->layout->publish work model. It is a great strength of the software: take advantage of it.
4. GUI. AC has a GUI that you HAVE to learn. Once you get it, you get it; but if you analize it... well... you'll see it lacks a lot. The features about the work environment are awesome. Export and import workspaces, and set them with a few clicks is FANTASTIC!. But the rest of the GUI is just confusing, in the sense that it lacks consistency. I mean, open up and compare the settings window for walls, doors, columns, slabs, zones, dimensions, levels, text, lines, grids, etc... and you'll see. Yes... there are some elements of consistency, but in general you have to dig into every window to know where a parameter is. Revit's GUI is not that good either, but the simplistic manner in which it shows properties (like a spreadsheet), makes it easy to learn, instead of learning a different window for each tool. You know what I mean.
5. Listen to the userbase/clients. You may come up with ideas to implement on the software, based on technology and new standards. That just gets you halfway. The userbase/clients is where the software gets tested and used in real life situations. That's the other half that's missing. Autodesk already learned this lesson. Just look at the complete transformation they're doing with 3ds max.
2010-05-15 10:03 AM
oreopoulos wrote:Yes do it.
Buy Revit and migrate there...
2010-05-15 10:06 AM
NeckoFromSarajevo wrote:good idea! At least, you did what you should have done a looong time ago.
my Revit 2011 DVD is on the way . . .
2010-05-15 10:18 AM
2010-05-15 01:20 PM
owen wrote:Technically they could do both, but in practice I think it would be a poor choice. If you maintain 32 and 64-bit versions, there will always be the risk that something will go wrong as projects move between them. For example, the 64-bit version will allow projects to grow to a size that the 32-bit version cannot open. And there will always be scope for very subtle bugs arising from the different word sizes as binary data is read/written.
do you have any insight as to why they would be going 64-bit only on the Mac side?
2010-05-15 01:48 PM
2010-05-15 04:43 PM
2010-05-15 05:33 PM
