2010-05-10 05:56 PM
2010-05-17 08:37 AM
owen wrote:ThankssinceV6 wrote:Agree 100% .. Great post in general but excellent summary of the major areas Graphisoft needs to address.
If GS wants to improve AC, in my opinion they should look into:
1. Database parametric engine: In Revit, you really have live views of a single database. If you have several views open and select a door in one of them, it gets selected in other views, and changes are realtime. In AC, you may have a plan view and a section view opem, but they are not live and connected, and get updated only after you click on the other view. Even worse: AC bases almost everything on the floor plan, so while in Revit you click in a section view and the software responds like "the user selected a door", AC works like "the user has clicked a point in a section view, in the coordinate x=2 y=1.8, which based on the floor plan and elevation data, corresponds to an area enclosed by a door, so, the user has clicked on a door: select it".
2. Remove the 80's thinking about software: if sketchup and revit can make components and families without programming knowledge, why AC can't do it?
3. Improve the model->view->layout->publish work model. It is a great strength of the software: take advantage of it.
4. GUI. AC has a GUI that you HAVE to learn. Once you get it, you get it; but if you analize it... well... you'll see it lacks a lot. The features about the work environment are awesome. Export and import workspaces, and set them with a few clicks is FANTASTIC!. But the rest of the GUI is just confusing, in the sense that it lacks consistency. I mean, open up and compare the settings window for walls, doors, columns, slabs, zones, dimensions, levels, text, lines, grids, etc... and you'll see. Yes... there are some elements of consistency, but in general you have to dig into every window to know where a parameter is. Revit's GUI is not that good either, but the simplistic manner in which it shows properties (like a spreadsheet), makes it easy to learn, instead of learning a different window for each tool. You know what I mean.
5. Listen to the userbase/clients. You may come up with ideas to implement on the software, based on technology and new standards. That just gets you halfway. The userbase/clients is where the software gets tested and used in real life situations. That's the other half that's missing. Autodesk already learned this lesson. Just look at the complete transformation they're doing with 3ds max.
2010-05-17 09:35 AM
2010-05-17 10:47 AM
2010-05-17 10:59 AM
NeckoFromSarajevo wrote:I always thought AC was to be a Architectural design tool, not render tool.
This pics was renderd in program that cost 99$ ! All 3 togeter took about 15 minutes on my comp which is old now comparing to new CPUs and GPUs
Is ARCHICAD 14 new render engine able to render like this ???? OFC no !
My point is that im architect and i need tools to design my architecture. Archicad is great program in some fields but as a modeling tool its very weak and i start to loose my time working in archicad cos i have to battle with software instead doing my design.The old thing comes to mind - the harder to design - the harder to build.
p.s. you dont have to change your software like me but i understand your fears...you are scared cos its hard to admit that your architectural tool sux !So good luck for You.
2010-05-17 11:07 AM
NeckoFromSarajevo wrote:I've never made any building on green ice...
Look at this pic.
2010-05-17 11:52 AM
2010-05-17 12:57 PM
Rafal wrote:WORK IN PROGRESS MAN, you just cant read all textNeckoFromSarajevo wrote:I've never made any building on green ice...
Look at this pic.
2010-05-17 02:35 PM
2010-05-17 03:06 PM
Philippe wrote:There is no need for this rubbish here Philippe, get off your high horse and get back to the topic at hand.
you do not even see this kind of crap in the first year of bachelor
First of all, maybe a couple of arch summer sessions in a good school...
2010-05-17 03:16 PM
