Archicad 14 New Features
Dennis Lee
See what's on youtube!
http://www.youtube.com/user/Archicad#g/c/5C1926DD91A70C7B
Personally, not much in it for me at all!
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
310 REPLIES 310
fuzzytnth3
laszlonagy wrote:
fuzzytnth3 wrote:
...and where there used to be a command in the AC13's Help menu there isn't in AC14
Strange, I have the link:
Help\ArchiCAD 14 Downloads
Ah in AC11 and AC12 the menu item was called ArchiCAD xx Goodies but it changed in AC13 and 14 to Archicad xx Downloads
Downside of using ArchiCAD for so long
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
ares997
Selecting a circle then trying to do a multiple offset cmnd (ctrl+alt) doesn't work. It works with everything else but doesn't seem to be an option. Am I missing something?
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
Erika Epstein
Use the multiple off-set icon and it works as it should.
The only problem is that the new circles are comprised of 2 half-circles instead of one complete circle like the original.
Bummer.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Rafal SLEK
I don't know if someone find this undocumented New feature for ArchiCAD 14 on MacOs — now it is possible to choose attribute from list by writing partially name by keyboard:
http://www.youtube.com/watch?v=lltc3JfYk68
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Wow, thanks, I didn't know that.
It is also possible on Windows.
You type the first one or two letters of the attribute and it jumps there in the list of attributes.
It does not highlight all possible matches, only jumps to the first occurrence and highlights that. If the key combination is entered again, it jumps to and highlights the next occurrence and so on.
Rafal SLEK
On windows it works as in previous AC version. Only first letters are allowed and it jumps to attribute name.
Now on MacOs it works for most parameter lists (even in library parts) with any name fragment. Only letters.
In Pen & Colours - it is little different - letters doesn't work only digits! 🙂
Funny is that it is allowed to find pens by their thickness (Pen weight) — eg you could write 0.35 and all such pens will be highlighted.
Line types doesn't work at all
I still search for more such new features...
Best
Rafał
That is a killer tip / hidden feature! Thanks!!
Attached is a screenshot of part of the material fly-out from the Info Box after typing "pine" with the material list shown - only materials containing the word 'pine' are highlighted.
I played some more, and letters do work. I have various pens labeled as 'skin' or 'core' pens, and they highlight. It is just that the highlighting is a bit too subtle. (Any highlighted done by fading /etc can look just like a valid pen - I think in the pen table it would have been better to draw a line through the rectangle of the unselected pens, or perhaps a border around the filtered pens.)
Very cool stuff, Rafal. Thanks! Keep up the search. 😉
davide
what does it means the number before the material 04|.... 05|...... 09|.... 12|........ And why there isn't 10|... 11|..... thanks
iMac i7 late 2009
10.13.6
Archicad 24
The numbers are 2004 CSI MasterFormat divisions.
Jared Banks, AIA
Shoegnome Architects
