‎2010-02-09 09:10 PM
‎2010-04-22 01:05 AM
KenMcN wrote:Yes this used to be a problem, but i thought it had been fixed in AC12? Anyway this (ACLs) doesn't seem to be the problem (can be opened by other means by same user) - something fishy is going on with the BPN files too so need our IT guru to investigate further.
Owen
Have you checked permissions on the 'corrupt' files?
I've found Archicad doesn't always inherit the permissions of the enclosing folder, as it is set to do via OSX Server (particularly if Access Control Lists are used).
Sometimes this prevents other people from opening a file.
Just a guess…
KeesW wrote:back to the speculation ...
Any chance of getting back to the topic - i.e. ArchiCad 14?
‎2010-04-22 05:47 PM
KeesW wrote:How about any idea if anyone has caught wind of a potential release timeframe? I could assume it would be in the fall just like AC13 was last year.
‎2010-04-23 04:52 PM
‎2010-04-23 06:42 PM
redworks wrote:Who do they think they are-Apple? Actually, I really wish they would give us some kind of build up. My boss is thinking no upgrade this year. This will be a first, but our workload needs to pick up drastically and I know we are not the only ones. Graphisoft needs to market v14 even to existing users. Just my thoughts.
nobody really gets that kind of information about archicad's lunch................until release day.as the story goes just wait and watch,hope and believe, get it and an ARCHICAD IT.....................
‎2010-04-23 09:20 PM
‎2010-04-24 06:35 PM
‎2010-04-25 10:29 PM
NeckoFromSarajevo wrote:... this is just a little investigation on the "other" BIM (did someone said Virtual Building?) application's forum...
cmon...dont loose your time and write here on this forums what you want and what you wish . . .cos you will not get it !
‎2010-05-04 12:25 AM
‎2010-05-04 12:51 AM
Steve wrote:Well, don't forget that last year's release (AC13) was exceptionally late - compared to the previous versions since they switched to the yearly cycle - ostensibly due to the necessity of getting the shift over to 64-Bit OS correct (even if not complete on the Mac side).
Perhaps we will see the new version sooner this year than last. My unreliable source tells me that beta testing is over now.
Is that true?
‎2010-05-08 10:19 AM
