Archicad 16 - adjusting wall in 3D
Hi everyone!
I have a problem - when I try to adjust a wall in 3D window with Ctrl+click, it suddenly ends up nowhere - it does not end in an intersection, or in another wall in the drawing, as it is supposed to be. The problem is only with the walls, beams act like normal and I have no problem with that.
Thanks in advance for the help!
6 Replies 6
Illustrated - This is what happens.
Edit:
I have installed Archicad 16 - 64-bit, Windows 7 - 64-bit
Updated Hotfix 3270.
Make sure you have the wall tool active or else the SELECT - CTRL click method of trimming will not work.
It should work the same as it does in the plan window.
I am absolutely sure I have selected the Wall tool. It should work the same as it does in 2D - I know that, Barry, that's exacxtly what my problem is - that it doesn't. And what is more surprising to me - it doesn't work only with walls.
Could it be the arrow (selection) tool is not set to normal selection?
I am having the same problem. The ADJUST doesent works in 3D and in 2D. Using adjust command, the line extends to the wrong direction !!!
In 2D and in 3D just fine here!
