2017-03-22 11:42 PM
2017-03-23 01:52 AM
2017-03-23 02:14 AM
2017-03-23 03:06 AM
2017-03-23 04:34 AM
2017-03-23 04:41 AM
mike_92_aus wrote:Excellent.
Thanks Barry, latest build has fixed the issue for me. I thought it was a new feature, must have been a bug.
2022-12-07 07:49 AM
I've got exactly the same bug in Archicad 23. I hope I won't have to upgrade to AC 26 to fix it.
2022-12-07 08:10 AM
I am not using 23, but I am not seeing any snap guides coming from a user origin or project origin.
Can you post a screen shot of your problem?
That may offer some clues.
2022-12-07 05:33 PM
I'm trying to drag a fill on a horizontal path, but when hitting Alt+A the snap guide goes from the point I'm at to the origin, instead of going on the horizontal path that I started.
2022-12-08 06:35 AM
ALT+A is the shortcut for lock angle.
If I start to drag the fill and then press ALT+A, it lock in the direction I am dragging but does not create a guide through the origin.
If I press ALT+A before I drag, then yes I get a snap guide going through the origin.
If you want to drag horizontally you just need to drag and follow the short temporary snap guides.
So long as you stay close to that guide it will snap to it and there is no need to press anything on the keyboard.
If you need to drag horizontally but you need to snap to a point no along that temporary snap guide, you can just hold SHIFT and move you mouse where ever you want.
SHIFT will constrain (lock) to any of the pre-set constraints (horizontal, vertical, 45°).
ALT+A after you start to drag will lock to the exact angle you are stretching - not necessarily horizontal/vertical.
So you are better of to hold SHIFT.
