2022-08-26 12:45 PM - edited 2022-08-26 12:49 PM
I created a comparison video between 25 and 26 where you can see the problem between the two versions.
This cannot be considered a bug because it is not something that is triggered with a certain action.
It affects the total workflow of the software and the on-screen quality.
Also you can see that transfering a file from 25 to 26 may change the text box size of the text box that makes the and put part of the text outside the borders.
I am using of 43 4K Dell Monitor
This was detected from other users also.
2023-06-06 02:34 AM - edited 2023-06-06 02:43 AM
That is not a text position problem - you will see all of the text, just in the wrong position.
That is probably because in the Windows Operating System settings, you are using a screen scaling that is not 100%.
You can maybe try 200%, but definitely nothing in between.
You may have to restart your machine after making the change.
EDIT - just noticed thread was locked - seems not to apply to moderators.
So if you have more questions please start a new thread.
There was another post fairly recently with the same problem.
I am pretty sure it was screen scaling that was the issue.
EDIT again ... https://community.graphisoft.com/t5/Documentation/Text-in-text-boxes-is-clipped-partially-visible-bo...
Seems 200% might work.
2023-06-15 03:14 PM
Thank you for taking the time to find a solution.
We kindly ask all of our users to leave the RenderingAPI registry unchanged. The original issue in this post is already fixed in UP3 (50xx) of Archicad 26. The other problem Mjules brought up in the discussion is text clipping, a result of 4K rendering and text scaling set above 100%, which we will address in the next update (60xx).
As a workaround for that please change the text scaling back to 100%.
Thank you for your understanding.
Kind regards,
Norbert Kucsma
Technical Support Engineer
