2025-09-24 10:24 AM
Since the 6003 update, Archicad crashes when trying to copy parts from a hotlinked module.
(Groups suspended > select one or more elements from the hotlink > ctrl+c > ctrl+v > crash)
Please fix this urgently!
Operating system used: Windows 11 23H2
2025-09-24 03:23 PM - edited 2025-09-24 03:23 PM
Can you paste them back into the Hotlinked Module source file from you copied them? Or will that crash as well?
Will it also crash when you start a brand new Archicad project based on the default template and paste into that file?
2025-09-25 04:37 PM
Just to be clear: the crash happens in the main project PLN file (into which the MOD file is already placed).
Before the update we could use group suspension and select a single element or a few elements from the placed module (e.g. a wall or a single fill).
Then use ctrl+c and ctrl+v to copy and paste this elements somewhere in the view, apart from the module content.
After making the selection of hotlink parts, the crash occurs when hitting ctrl+c.
All colleagues have the same problem, regardless of which project file or module.
2025-09-26 03:30 AM
I just upgraded to 6003 to try and I could copy & paste from a suspended module with no crash.
Does this happen to you with any module in any file, or is it a specific module in a specific file?
I am quite surprised you can do that as you can't drag a copy from a module.
I am sure you are aware you can at least ALT-click to get the properties of the element, and then place a new one.
2025-09-26 09:49 AM
Hi, just tested with a new file and new module (general template 28) and the problem doesn't occur.
When testing the relevant modules within the clean file, it does crash.
So: it appears to be module specific. However, not too specific as multiple of our current project files with hotlinked modules have this issue.
We don't know yet what the common denominator of these modules could be...
2025-09-26 10:40 AM
That is the problem to determine.
If it is just particular modules, is it particular elements in those modules?
If you re-save the module, does that help?
If you are crashing and the Bug Reporter comes up, complete the details, take note of the report number, and then send it off.
Then contact your local support with that report number, and ask them to check it out.
They hopefully will be able to tell what caused the crash.
2025-10-27 09:30 AM
Others have reported similar crashes after the 6003 update. In the meantime, try exploding the hotlinked module or breaking the link before copying elements, as a temporary workaround. Also, make sure your graphics drivers and Archicad library are up to date.
2025-10-27 09:56 AM
So now the question is, was is peculiar to some of Robs modules and not others, in that some crash and some don't?
Is it the element being copied.
Is it a MEP element.?
Does it have a Design Option set?
Does it have a Renovation status different to other elements?
I am just guessing.
Hopefully the crash report will shed some light on the problem.
