2007-06-18 03:48 PM - last edited on 2023-05-25 04:59 PM by Rubia Torres
2007-06-21 06:36 AM
nats wrote:There is actually a pretty good way to work with one or two modelers among a sea of drafters.
Seriously though I do appreciate the comments I have received and am trying to look outside the envelope of 2d but it is difficult because I am working in a solely 2d environment in this firm and even if I actually ever 'got it' there are another ten people who would still be working in 2d.
2007-06-21 08:01 PM
Matthew wrote:nats wrote:
........the modeler(s) ..... models to support the design process.......over by hand. The model can then be used ......... takes advantage of the model for....... modeling skills, and also makes effective use of the drafting skills.
......just making the model a little ...... completely detailed in the model and require ......amount of drafting, but I don't see t.........
2007-06-21 10:25 PM
Joseph wrote:I can't speak for others but I use the term "modeling" in a broad, multidimensional, virtual building sense. That is, the building model is a simplified, computer-based abstraction of the proposed building. This is much more than just 3D modeling since the entities we use are identified and constrained according to properties and parameters appropriate to their type. In 3D modeling programs such as form•Z the various shapes are undifferentiated except by position, shape and color.
Matthew, this word modeling is repeated alot in AC world. I always think of MODELING as doing "drawings" in the 3D window, but I get a feeling most people do it on the plan window and take care of the rendering and visualization in the 3D window. Could you put some flash light on this topic?
2007-06-21 10:44 PM
Matthew wrote:Exactly. It's a lot easier to draw walls and locate windows in plan view. It's a lot easier to locate trim pieces and align roofs in elevation. It's all about where it's easier to do the exact task you are working on.
Whether this modeling is done in plans, 3D views, sections, schedules, library parts, or linked models, modules and specs is simply a matter of whatever is most effective
2007-06-21 10:52 PM
TomWaltz wrote:Yep, it's all about getting the job done.Matthew wrote:Exactly. It's a lot easier to draw walls and locate windows in plan view. It's a lot easier to locate trim pieces and align roofs in elevation. It's all about where it's easier to do the exact task you are working on.
I usually only work in the 3D window for looking at things I cannot see in other views and make minor edits. But that's just me. I have one person here who works in the 3D window half of his day because he's more comfortable with it.
2007-06-22 12:41 AM
2007-06-22 01:31 AM
Joseph wrote:Kind of a broad subject. Perhaps you should start a new topic.
Tom & Matthew,
I like what you two are saying, yet like to hear how one can utilize the 3D window better for different components of a building?
Thanks,
Joseph
2007-06-22 02:43 AM
2007-06-22 07:44 PM
TomWaltz wrote:
You may as well ask "how do I use Archicad." That's a hige question, probably one that would take a day or so to teach as a seminar in person.
