2022-07-21 01:21 AM
Hi, I am having some trouble with an Archicad File. I clicked on the exterior views in my view map, and it started loading, with a message that reads "Generating 3D document, calculating split polygons". This message remained loading for at least 15 minutes before I decided to close the program altogether. I restarted my computer and reopened the recovered file, still it came up with the message that said Generating 3d document calculating split polygons. I also tried opening the bpn and the same was still the case. Any ideas?
2022-07-21 03:19 AM
Start Archicad without opening the file.
Then go through the FILE > OPEN menu to manually search for the file.
Use the 'Open & Repair' option to see if that has any effect.
Might be bad objects in 3D.
It might not do anything, but is worth a try.
2022-07-21 06:10 PM
Excellent, that seemed to work. Thanks!
