Friday
I've opened up my file and my window has split into two. As you can see below a quarte of the screen is the workable area then the remaining screen is grey. Has anybody had this problem how do you bring this back to 1 screen.
Solved! Go to Solution.
10 hours ago
Thanks for the message Barry. This was not the case. It was a glitch in Archicad 27. After i restarted the computer the file was working correctly. This was very weird as every other project was opening correctly.
yesterday
You seem to have a very wide screen format?
That should be fine.
I would play around with manually resizing the Archicad window and even the plan window to see if you can adjust it.
Then if that work you can maximise it again.
But I don't see those buttons in your screen shot - I assume you may have just cropped them off.
10 hours ago
