ā2014-09-11 10:12 PM
ā2014-10-07 10:12 PM
ā2014-10-07 10:48 PM
ā2014-10-08 10:10 AM
ā2014-10-09 12:29 AM
ā2014-10-15 12:20 PM
methy wrote:Methy,
Hi there
I have noticed recently when I have 2 versions of Archicad v17 running
In the Task Manager - Processes one of them will sit at the typical 500mb of ram usage while the other one is currently using 2.5 GB of RAM
(2,576,928 K to be exact it seems to be running at a maximum as the number does not change)
(this is while a Cross Section View is open and computer is Idle)
It has only recently started doing this, did they mess something up with a recent update or has my archicad 18 installation affected something?
Anyone else having similar problems?
ā2014-10-15 06:11 PM
ā2014-10-16 09:43 AM
Barry wrote:Yes. If more then one ArchiCAD instance is running there is communication between those to share navigator data and provide the possibility of cross-linking.
Does this background communication apply even when the files in two or more open sessions are not linked in any way?
Barry wrote:Yes, with the next ArchiCAD 17 hotfix we will address this in ArchiCAD 17 as well.
Also if there is to be a fix for 18 will there ever be a fix for 17 as well?
ā2014-11-02 10:42 PM
ā2014-11-03 09:03 AM
ceroz wrote:We've discovered the source of this problem, for details see:
When this issue is going to be fixed? I got two versions 16 & 17 START edition and I'm still unable to work with two instances. This is really annoying so please release the update ASAP.
