2021-06-20 06:24 PM
Solved! Go to Solution.
2021-06-20 07:17 PM
Jan wrote:Hi,
Hello !
After I found that blue circle on corner which is not easy to wait all the time by the way,
But even after blue guide snap set it still works like that. It is not sitting precisely on the line as you can see, and that zoom is not too much close to blame magnification.
2021-06-20 07:10 PM
2021-06-20 07:17 PM
Jan wrote:Hi,
Hello !
2021-06-21 03:57 AM
Karl wrote:
First, the delay is controlled by a setting in the Work Environment. See the attached screenshot and change the default 1.5 seconds down to something smaller if you wish.
2021-06-21 10:31 AM
2021-06-21 11:14 AM
2021-06-21 12:07 PM
Braza wrote:thank you Braza , that works nice but I still have little issue with wall connections , all layers here are at correct priorities and connecting well, but that little gap and line which appears and disappears randomly.
Jan wrote:Check your Wall Closure "Dimensionable on 2d" option.
Overally there is a problem that still exists. see that image below.
2021-06-21 06:01 PM
2021-09-02 06:27 AM
Hi Karl,
If I am working in a two-story building, first I first place all walls in the ground story then I do all reference lines to create a wall for the first story but the problem is I can't match the same line of the wall.
2021-09-02 09:37 AM
You can copy and paste walls from one storey to another and they will paste in the same position as the the other storey - just in the new storey with regards to height position (& they will belong to the new storey).
Or you can turn on your Trace & Reference and use another storey as the reference, and simply trace over where you want new walls.
There is no need to set up reference lines to position new walls on another storey if that is what you are doing - or maybe I misunderstand your problem.
