‎2018-08-07 11:02 AM
‎2020-04-28 11:59 PM
‎2020-07-22 10:04 PM
jl_lt wrote:
Also at first i was also annoyed at the aparent small lag with selection
‎2020-07-23 02:41 AM
‎2020-07-24 08:05 PM
Brett wrote:
JohnJay, you can always do your stairs in AC 20, convert to a Morph, select Morph and save as an object.
put in future AC library whatever version, place it as an object. If you want to edit it convert back into a Morph. Works for me and takes a few minutes
‎2020-07-27 09:55 AM
‎2020-07-27 10:56 AM
‎2020-07-27 05:11 PM
KrisM wrote:.
I personally like the interface of Revit [...]
Shortcuts - Revit has a different system - two keys for everything. While I initially found this odd, this has turned out to be my favourite method. [...]
Revit attaches things which you may not want to happen and if you are not being very careful, objects move around without you knowing. [...]
‎2020-07-28 07:25 AM
‎2020-07-28 10:04 AM
‎2020-08-04 08:08 AM
