2004-07-02 12:03 PM
2004-07-02 01:45 PM
Vincent wrote:This is the scale of the drawing in the layout. This can be different from the original scale of the drawing if this has been overridden and changed in PlotMaker (not recommended as a general practice).
Hello !
We don't quite understand the use of AutoText (with reference)..below our questions...
1.
What does Output Scale do?
2.The only way to accomplish what you want here is with the Title Type. The Master layout has no ability to know what drawing is placed on it (a wish list item?). I don't see why you can't make the stamp you want as a Title Type and move it to where you want it on each sheet. Perhaps the best arrangement would be to make a Master with the basic information and graphics with a place holder for the drawing title. (You are aware these can be moved independently of the drawing?)
Clients want to make a detail-book; they place each detail-view on a unique layout with its own Master Layout. Now they want the name, number and scale of this drawing in the lower-right corner of the layout (in Dutch we call this the stamp..?). We want to do this with Autotext but the Drawing name, number and cale only work icw a Title Type; this is not the answer. When I set a drawing as reference asn I place Autotext with reference in the master all the text in the layout is as the reference drawing. When I place the Autotext with reference in the Layouts it's actually not really a practical Autotext-item anymore; I have to dot it for all details again...
3.Same here. I can't imagine and haven't run into any situation where it would be useful.
We can't come up with any practical example when to use Autotext with reference.When do you use this? Can you give examples of practical situations to use this. I read the manual but we can't put it in practise.
4.Since I haven't come up with any uses for the "Autotext with reference" yet I can't ... NO WAIT, I have an idea. Just a minute, I have to try this out.
When we use Autotext with reference some items that are in the list are also there under AutoText; what's the difference in practise; can you give examples in practise when you, for example, use layout name from the AutoText list and use layout name from the AutoText with reference list
2004-07-02 02:04 PM
2004-07-02 03:42 PM
2004-07-02 03:56 PM
2004-07-02 05:06 PM
2004-07-02 09:05 PM
