Create Stair using Selection - 900mm run length
Can anyone help? I need to make a stair from a selection. However, the minimum depth (from base of stair to top of stair measuring the goers in total - stair run) which Archicad can cope with is 1200mm. I need to make a stair with a run of 900mm with the stair being a trapezoid.
Cheers
Baz
3 Replies 3
Djordje
Can you post the screenshot of the PlotMaker settings?
I am guessing your riser to tread ratio does not allow for a shorter stair.
I have been doing steps 300mm "high" but you have to tell PlotMaker to allow you to do it! 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje,
You mean StairMaker I presume. Unless you know some PlotMaker tricks for building stairs
Djordje
Matthew wrote:
Djordje,
Ouch!
Of course I do!
This is what catching up with two weeks' worth of ArchiTalk does to you ...
Djordje
HP Omen
